waddycall
- Cornwall
My mill has a worn (but still useable) worm wheel which acts as a bronze half nut for the x axis and is connected to four ball ended handles with a clutch for rapidly traversing the bed. It’s a very handy feature - finish a cut, squeeze the ball handles to release the clutch and throw the table back to the start to take another bite without stopping the machine or disengaging the power feed.
The worm wheel is badly worn in some places and not so bad in others. It’s an enveloping worm wheel that wraps partially around the feed screw.
Replacements aren’t available so I’m day dreaming about making one (purely hypothetical at this stage). I understand you really need a universal dividing head geared to the table feed of a universal mill to correctly cut this kind of gear (correct me if I’m wrong) and free hobbing is out of the question due to the enveloping nature - I don’t just want shallow teeth.
Could I rough this out as a spur gear with the cutter at an angle to approximate the helix angle of the screw and then use a home made hob to get it to final shape?
Or can someone else make me one
