Hi I'm currently doing a car restoration project. I'm cutting out panels to get to rust then welding the original panels back on again in places. Just looking to put a good coat of paint on the inside of these panels. However I'm worried now if I paint on some 2 pack epoxy primer it might not cure as I'm working out of a cold shed that's not insulated. I can heat up the panels with a heat gun prior to paint and put a gas heater on as well, but overnight then temperature will drop to 0 degrees.
Is there a good primer that will cure even at colder temperatures? Any one used any with good results?
Many thanks.
Many thanks.
