Good suggestion but last time I did that I dropped my phone from the roof. I'd prefer a cheap dedicated device.If you have a smart phone you can get a very accurate inclinometer app for it
...also worth checking with a sine bar....
You make a 30 degree setup as you describe and then set the cheap inclinomter on it to see if I matches to check its accuracy.How would you "check" something with a sine bar? A sine bar is more for "setting" an angle.
Pick a number: 30 degrees (standard school geometry set triangle) and describe how you'd check that with a sine bar. The operation needs other equipment as well as the sine bar. You also need some foreknowledge of the angle in order to pick the correct gauge blocks and then something else (e.g. dial gauge) to sweep the sine bar.
With a digital item, you set it to zero on a flat (not required to be horizontal) surface, then sit it on the item resting on that surface and it tells you the angle directly.
I'd just set up the sine bar flat, check the inclinometer against that, zero the inclinometer, then bung the old shaper gauge under the nose of the sine bar, after having set the shaper gauge with a vernier micrometer according to my Presto Book sine tables, then see what the reading was.How would you "check" something with a sine bar? A sine bar is more for "setting" an angle.
Yep, that's the sort of thing I may use it for. In addition to general construction work.i have a wixey one 22 quid its brill for setting up stuff on miller and my gauge i made for setting angles on the belt sander sharpening chissels and blades for the wood plane
For milling yes, but for building stuff, nah….you dont need such accuracy. Joiners were cutting roofs long before electronic jiggery pokery was invented!Yep, that's the sort of thing I may use it for. In addition to general construction work.
