Hi,
I’m looking for some CNC plasma cutter and due to space challenges, I’m thinking of the ArcDroid. However, as it’s expensive I’d like to hear your honest experiences about its accuracy. YT videos I’ve seen, many look like the holes meant to be round were cut oval. Then read in the support forums that it’s not capable of making straight cuts etc. I haven’t found any specs telling the repeatability or accuracy of that thing. When thinking of the construction, you have one axis which has that arm attached. Torque, long arm and the movements, so even a slight play will be exponentially visible at the torch. Can’t wrap my head around to see this could possibly make accurate movements. Compared to linear X-Y rail construction which is naturally accurate. I understand that plasma cutter is not precision tool, but is this ArcDroid within the limitations of the process accuracy? Do you get round holes and straight cuts with it? Please give me honest experiences of its accuracy? If I’ll decide to spend that much money on a device that has end results “roughly there”, I’d be ****** off to myself.
Thank you in advance
