I can remove the hive receiver this evening. I can then put a temperature probe on the radiator to log the highest measured temp overnight.Isolate the Hive stuff in order to check basic heating/boiler operation.
Asking the obvious, you have replaced all batteries?I can remove the hive receiver this evening. I can then put a temperature probe on the radiator to log the highest measured temp overnight.
As said above I have taken the hive thermostat out of play by disconnecting the receiver.Asking the obvious, you have replaced all batteries?
This is in the townAre you sure?
It's only 7° here and I'm slightly less rural than you.
I bled one radiator yesterday and recovered a bit of air. I will have to do an upstairs oneBlocked system, air lock? Can you operate the heating without the Hive to eliminate that?
I'm gonna disconnect this one soon, I just haven't got the energy for it this eveningI had the same issue with my heating coming on of it's own accord. My system has a wireless 'stat and I'm pretty sure a neighbours device was interfering with my own. I tried different settings on the reciever, made no difference so ended up getting a new stat. Problem solved.
