I see that ^ (never seen before) however it doesn't appear to be built the same as the OP's.
Well would you look at that!
The OP's tap is just adjustable, not whilst down in the bore.There are many ways to skin a cat...
But I do understand what you're saying.
Any names/numbers on the shank?I have adjustable reamers but haven't seen an Adjustable tap before. This is M18 (spark plug thread) and popped up on another forum then sent to me by a pal.
Any suggestions on its prupose/application?
That's a good one, but they usually use oversize taps for that. I think an oversize tap is easier/cheaper to produce than an adjustable one plus you can't use this one in a blind hole.Another possibility is for use if the item is to be (electro-) plated. Then the pre-plated thread needs to be oversize so it is correct after plating.
And it has straight flutes so the chips are going to go straight down into the combustion chamber if used on a mounted cilinder head.The OP's tap is just adjustable, not whilst down in the bore.
I have one like this, it goes right into the spark plug hole before being expanded into the thread and then extracted outwards bring any debris with it.
I have no idea, that's the only picture I have.Any names/numbers on the shank?
