Hi All,
Having got a static 3 phase converter with idler motor to power my Harrison mill, the next step is to put a plug back on the mill so I can connect it to the output on the phase converter. When I got it, the mains plug had been cut off leaving 6 wires which had previously been connected to the mains. I have traced these and confirmed with continuity on the meter what 4 of them do:
L1 = Brown wire connected to the main rotary isolator on the side of the mill labelled L1
L2 = Black wire connected to the main rotary isolator on the side of the mill labelled L2
L3 = Grey wire connected to the main rotary isolator on the side of the mill labelled L3
Earth = Yellow and Green wire
Below is the back of the main rotary isolator on the side of the mill
Then there are two other wires, both brown. One goes to a blue wire on the red and yellow emergency stop pedal you can press with your foot under the front panel. The other goes to the red stop button on the front panel.
The back of the front panel looks like this:
The mystery brown wire going to the stop button on the front panel is the one going into the orange side of the orange and green switch in this picture above, the output from this orange switch goes to a terminal behind the one labelled 13 on the contactor labelled 21.
The other mystery brown wire goes to the emergency stop pedal. Out of that pedal there is a brown wire which is joined to a red wire in a bundle of cables that terminate on the main rotary isolator on the side of the mill. This wire is one of the two in the photo of the back of that isolator, and they are labelled C1 and C2 on the isolator. I've tried testing them for continuity with the meter but get nothing, I thought maybe because it is going through the stop pedal that has broken the continuity?
I know I need to wire up a 3 phase and earth plug to the L1, L2, L3 and Earth wires but I don't know what to wire the other two brown wires to for the stop button and stop pedal.
Can anyone point me to somewhere which explains how these switches should work or possibly explain it to me if you understand it please?
Thanks for any help you can give me.
Angus
Angus
