novice_mechanic
New Member
- Europe
I am currently in the process of applying some repair patches to the bug & thought of buying a hand-operated shrinker and stretcher to create complex patches more easily. So I did for 150 Euros on Amazon. Before buying one, I did some research and found out that these machines don't work straight out of the box. Collectively, I would say I saw a total of 3 Hours' worth of clips on YouTube on how to get Shinkers & Stretchers in good working order.
Upon receiving mine, I put it on a vice and got straight to using it, but as expected, it did not function properly. The Stretcher worked to some degree, but on the other hand, the Shrinker, the one I needed to use, did not, so I got to work on that.
Based on YouTube recommendations, I began by disassembling the machine, and I immediately noticed the First Issue. The other faces, besides the Jaws, on which the whole mechanism slide on, were all uneven & at times the Shrinker would bind. Sanded the side faces with 220 Grit, working up to 320 grit on all pieces until they were smooth (See Image 1). This made the inner workings of the Shrinker work way smoother, but I have encountered another issue.
Image 1:
The Second Issue occurs when the jaws engage with the sheet metal and initiate the shrinking process to pinch the material together, the jaws tend to slide, indicating that they may not be gripping the sheet metal properly. I then proceeded to dismantle the Shrinker Jaws again to clean out any debris that may clog them, which could prevent them from gripping properly. This too did not work, so I cleaned the Jaws a second time and this time filed the teeth of the Jaws (See Image 2). This gave them somewhat a better grip, but despite these amendments, they did not contribute to any improvements.
Image 2:
On top of these attempts to make the Shrinker work properly, I:
1. Bent the retaining clip tips to 90 Degrees & made sure they are the same height (See Image Below)
2. Made sure that the thickness of the sheet metal did not exceed the maximum amount of the Machine (See Images Below)
At this point, I am considering replacing the Shrinker jaws with a better-quality pair. However, before I go down that path, I’d appreciate any recommendations or guidance on what I might be overlooking or doing incorrectly that’s causing them not to function correctly.
Have any of you experienced similar issues with the jaws sliding during operation and failing to grip the sheet metal effectively? I’m very interested in hearing if there are any further adjustments I can try.
Thank you so much for your attention and participation in this issue
Image 1:
Image 2:
