Hi
My disposable K2 Kärcher has given up and this time am looking for serious 3ph 5+ kW one.
While looking for a new one I stumbled upon topic of pump differences. All are of piston type but driven differently, axial vs crankshaft i.e. triplex. Also looks like axial ones can be of simple design like Kränzle wobble/swash plate and another I'm not even trying to name here:
That video can be hidden promotional agenda of course, but it is not alone in calling the triplex pumps superior. However I am not convinced, why axial pump with springs would be much less efficient than crankshaft one? Energy used to compress the spring is not lost and will be expended to move piston back and suck water in. While the crankshaft pump has to similarly move piston back and suck water in, but energy in that case is transmitted through crank/shaft. So what is your take on that? I am eyeing AR 1007 and Kränzle Quadro lines and the pumps are main difference. AR 1007 does not have integrated water tank and I've heard that is important. There is also weird discrepancy in official manual as the minimal permitted intake water pressure is 1 bar (p 5.1), yet on the same page it describes "Suction of water from open containers" (p 6.5.3). The local dealer only mumbled about AI translation...
That might be the best plan. I should get rotating jet nozzle for the Lavor and try if that makes a dent to the overgrown stone parquet. As I remember the normal jet did not.
