Hmmm, maybe some solid nylon rod and bore it.Has anyone got some 13mm HPDE or similar or a link where I can get some?
I only need 50mm x 50mm, I will need to cut, drill and shape, but cannot find 13mm thick.
Brittle perspex etc won't do.
kitchen cutting board.
Ideally black, but the thickness is the problem, 12 mm is too slim.Do you want it opaque? Something like nylon or acetal? You can get that in sheets but usually 12,14,16mm etc. nylon or acetal can be milled.
Needs to be as close to 13mm as poss and specs on line jump from 12 to 14, etc, so chancing it for a big lump of cutting board won't work.Commercial kitchen cutting board.
12.7mm would work if you have some? only really need 50x50mm?I might have some 1/2" if that's close enough?
That's the thing, I need it 13mm or as close as poss, I could mill it to 13mm but would rather not, I just can't find 13mm thick on line and I only need a bit.![]()
LEGITIM chopping board, set of 2, white - IKEA UK
LEGITIM chopping board, set of 2, white LEGITIM plastic chopping boards are easy to use, clean and care for. They are suitable for all types of food and are gentle on your knives. You can also serve food such as cheese or cold cuts on them. The material is suitable for use with all types of foods.www.ikea.com
Says 20mm thick. Very cheap.
That's the thing, I need it 13mm or as close as poss...
bread boards have a nice workable plastic.Has anyone got some 13mm HPDE or similar or a link where I can get some?
You're right, £2 for a pack of two at 20mm thick would be cheap. I was thinking of ordering some myself then checked the details... 5mm thick!![]()
what's it for?
