In both switch states, the left-hand winding has L1 top and N bottom.Uploading video to YouTube now. I've rewired the switch and have some progress - but I have no torque when reversing the motor - it just hums. Reversing the brown and blue cables to the motor reverses the direction (but the switch still only works when turned one way)
Would you say, as they've drawn it, the left hand winding should be the one with higher resistance?In both switch states, the left-hand winding has L1 top and N bottom.
Down - both windings are as above.
Up - the right-hand winding has N top and L1 bottom.
There are quite a few links between the switch terminals - could the rats have chewed one away?Reversing the windings makes no difference / the phenomenon remains the same - runs one way, hums the other way
Yes, I think so.Would you say, as they've drawn it, the left hand winding should be the one with higher resistance?
I've replaced every single wire nowThere are quite a few links between the switch terminals - could the rats have chewed one away?
Yes, I think so.
By making your own connections, you can reverse the motor normally?I've replaced every single wire now
