I have tried to ,until now.Don't forget the Coupe.....
I had successfully blotted the Marina Coupe from my mind...I have tried to ,until now.![]()
I went through 6 of them, I loved them!I have tried to ,until now.![]()
Oddly enough I was doing a bit today, on the Land Rover, nothing like an engine swap tho, I'd do that round the back in front of the garage spacesVery environmentally friendly. Every time it was used at least the driver could say he was using the bus.......
Something you rarely see these days, a nice bit of kerbside engineering. Most of my 20s I could be found fixing something whilst laying in the gutter.
Wasn't that the thing though? You could fix most cars with a handful of Imperial spanners while lying in the gutter; one pattern of balljoint, track rod end, brake shoes, wheel cylinder, alternator and wheel bearing for most Fords and another set for most of the BL stuff.Very environmentally friendly. Every time it was used at least the driver could say he was using the bus.......
Very true.Wasn't that the thing though? You could fix most cars with a handful of Imperial spanners while lying in the gutter; one pattern of balljoint, track rod end, brake shoes, wheel cylinder, alternator and wheel bearing for most Fords and another set for most of the BL stuff.
Now different examples of the same make and model car from the same year can have three different calipers, water pumps, timing belts... and forget changing a balljoint, it's a whole bottom arm![]()
Yes the Marina was crap, but so was everything else then. The Escort was crap, but Ford did very well in rallying, and provided engines that could be tuned. The rest of the car? Well it was swapped for bits that made the engine work well.
Outside of the moggy derived front suspension, the Marina and Escort weren't that different, but look how the Ford took off.
At 18 I used to come home from work (in a bank), get my suit off and then take my Mk3 Spitfire's gearbox out through the passenger door, single-handed. Before tea.Very true.
Tools: a 1/2" socket set + 1/2" + 7/16" spanner covered 95% of the tools you needed to swap an Escort / Cortina / Anglia engine ( I kept an alloy scaffold pole for many years - remove bonnet - pole over motor - sling with rope - 2 blokes to lift it out. Engine swap took 3 hours if you took a rest half way. Car owner buys beers that night.
Parts compatabiliy: I bought new brake disks for a Mk1 Cortina, box listed fitments from 1960s-late 1980s (Anglia 105E, Mk1&2 Cortinas, Corsair, Mk 1&2 Escorts, Transit van...)
I still have the Gordons imperial spanners and blue cantilever toolbox I got for my 17th birthday.
There's virtually nothing left of the Allegro though, it's a Honda in a cheap suit.
Did you have to do that every day?At 18 I used to come home from work (in a bank), get my suit off and then take my Mk3 Spitfire's gearbox out through the passenger door, single-handed. Before tea.![]()
I’ve still got one, taken dozens of engines out with it, last one was my son’s Mazda engine & box out about 15 years ago. I thought it really is past its sell by date, but it still worked ok. It was bought about 1970 I think.My dad used a Haltrac-style rope hoist lashed to a couple of old fence posts across the steel A-frames of the prefab garage roof to lift engines out... although it last saw action in about 1980 I think it's still hanging there.
