DVA
New Member
- United Kingdom
Hi all it’s probably been some time since I posted here, (if at all). I’ve recently bought a Cut-40 plasma cutter with air compressor which has a 13amp plug fitted to it. It can supposedly cut up to 6mm, however every time I try doing this it blows the fuses. The manufacturer has suggested I put a 20amp fuse inside instead. My understanding is that although technically it can be done, it’s illegal in the UK.
I do have a single 16/32amp rated industrial socket on a separate box which I use for my Mig welder. Although this may well be an electrician question, can I cut off the 13amp plug and instead fit a16amp (or 32amp) industrial plug on the end? I’m not sure I really want to do it this way as it will mean unplugging the welder every time.
Is the 20amp thing a problem or can this be done. The power cable for the plasma cutter is quite thick so at a guess it could be rated higher than 13amps.
Thanks
Thanks
