its fixed /nothing adjustable although i have pondered if i can make it adjustablelength of the master cylinder connecting rod could be critical! if it is not allowing the recuperating hole in the piston to open to the fluid reservoir thats the problem! set up on the bench you wouldnt see it!
so wouldnt adding inertia move a bit more fluid and do what i want ? maybe?It's to add some inertia to the moving fluid, helps damp out chatter or vibration on engagement, and stops you getting unwanted NVH - it's basically a tiny fluid flywheel. The inside of hydraulic engine mounts has something similar in function.
To go back to this reply, LHD/RHD should have a similar setup in terms of pedal heights/stops.only in pictures its fairly rare here being a lhd one
