Ratty
Putting the She in Sheds
Think I've sorted the aggregate side and will get a load delivered. I had a look at the site for the other shed - for the ratman's gardening/woods stuff (tools and machinery...approx 20' x 12'...bigger if ratman isn't looking) Whilst it was going to be a majorish job sorting the plot (removing tree stumps and levelling) I realised I could easily move the chestnut fence and re-route the track between two different trees and not only create a better space but may even be able to persuade the truck to drop the aggregate much closer to the site (and out of the way of the drive).
To continue from above...We got the site prepared for the second shed, this is the fence moved so the track will re-route through two different trees (just a small shrubby tree to remove). You can see the line where the fence was moved from which gives a nice flat area for the second shed which will be 6.5 x 3.5m
Former being built
With the size decided I then ordered a lorry load (7 tons) of crushed concrete (allowing 100mm depth for each site) which cost £17.95 per ton. We were able to get it tipped on two sites, the woodland one onto a tarp and the other onto concrete as near as possible to the first shed and started to barrow it in.
Borrowed a whacker to compact both bases. On my workshop shed base we spread a 50mm layer of an insulating aggregate that had been getting in the way for a year or more. Not really used as it should be but it got rid of it and saved a few quid on crushed concrete.
That was all done just before Christmas. Since then they've been sitting there awaiting the end of the looooong holiday and better weather.
I decided that the best route was to get a minimix in which will in fact be two minimixes. This will cost a bit more but it means we get 2 hours (total) of having the lorry on site and will leave a gap between deliveries so the former can be removed from the woodland site and the second pour can do the ramp as well as the first shed base...and a path I decided to upgrade. The path runs behind the big freezer and rather close to a ditch so needed more aggregate. That's when we did a run to the farm site and loaded a pick-up which was just enough to give it a firm base. Given enough time I could concrete half the garden
I'm learning all sorts of useful stuff, like to calculate the tonnage of aggregate you need to multiply the cubic meters by 1.5, that a round edged spade is much easier for shovelling hardcore and that I CAN do a certain amount of shovelling before my dodgy elbows start to scream.
Have decided also to lay mesh in both bases figuring there's no point spoiling the ship etc.
it's all got a bit slow again due to my mothers fall and my skipping up and down to London but we're almost set to get the concrete delivered...just got to muster up some extra labour for a few hours.
- looks like I'll have to pay a bit extra for it.
