Great, thats useful info. Thanks!I’ve got a Brennenstuhl. Decent.
A firewood supplier, who gets inspected, told me the proper way to measure firewood moisture is to split it and measure across the grain in the middle of the split face. Try to keep the pressure consistent between measurements and don’t press too hard.
14-20% is the aim - too wet and it won’t burn well, too dry and it’ll burn too quickly, and you’ll have lost some calorific value. Opinions do vary, though.
Didn’t think of that. I assume the meter probes have to be the same distance apart for consistency?Looks like you could..
There are tables on the Internet that show you the resistance for the moisture content.
They even cover different brands of wood!
At least a year off the stump, seasoned undercover and off the ground in a slatted shed is best. I used to stack, but it takes too long and find it better to make a loose pile (less contact between pieces). Up here we fill tattie boxes.Great, thats useful info. Thanks!
I've stacked about 8 tons of ash. It was cut between last November and Feb, logged but not split. Then sat in my yard in the baking sun all summer. I hope it will be ok. I will start burning some from the previous year so most will be at 12 months by the time i get to putting it on the fire. Need to stack another ton or so to get through winter fully on it.
I found that and tried last night. Reading more it seems like I'd need to drive nails into each bit of wood about 1.5" apart and then put the probes on them. I tried sticking my sharp.multimeter probes into the wood but couldn't get a reading. Then gave up and ordered the stihl meter.Looks like you could..
Ha. If the Rayburn was lit I'd try that.Weighing one block of wood
And put it in an oven on 50 celsius for an hour
And weigh it again
Put it back in the oven til its not getting lighter
Then you will know the exact moisture content
Can anyone recommend me an inexpensive moisture meter? I just want it because i am curious about my various piles of firewood. They seem to range from just over a fiver on Amazon upwards, but I dont want to go so cheap it doesnt work!
And weigh it again
Yes, it burns with a hiss, the steam escaping. You don’t so much burn wet wood as incinerate it using dry wood. Waste of time.The maths of burning wet wood is curious.
You have more going on than is instantly obvious.
You're not only raising the temp of the water from room temp to boiling, but also putting in the state change energy to vaporize it.
Because the state change alone sucks out energy from the fire box, you lower the burn temp, and limit the combustion of some of the less volatile compounds, so you then don't recover the energy from them either.
In short, it's a way worse idea than just thinking that 25% (etc) of the mass won't burn.
