Probably been asked a load of times before, but wanted to say hi as a new registration too.
I'm doing some garden building work and have decided to use some 100mm steel box form steel posts, 5mm thick as part of the support structure. I'll be needing to plate off the ends with a 200mm square at one end to screw down to concrete pads and slightly smaller size plates at the other end to fix to steel girder frame.
I've often thought that I'd like to learn how to weld, and have decided this might be the opportunity to do it.
1) Am I mad?
2) Am I going to regret this?
3) What do I need? (scraping the surface on bottle or not etc.)
4) Where should I get it? Screwfix etc.?
5) Would I be able to do this outside easily?
6) How long before I might be competent enough to actually do the job?
Thanks all !
1) Am I mad?
Thanks all !
