if you fit a diy fuse and 16amp setup you will need to have it checked if in the event anything happens it wont go well for you as your renting
just get the 16amp and have it wired to a blue connector and have that tested nothing else is needed anything else after that is your issue and not anything to do with the renting place
if you want to wire it all in just get the fuse and wire to a consumer unit in the shed and split what you need in there when you leave take it all with you
the issue stands if anything happens you will be at fault so remember that as that would mean they wouldnt have to rehouse you as its your fault if anything did happen
becareful within rented propertys
Thank you, I'll bear all that in mind.
No this is not a business, just for personal needs and pleasure, and a favour for a loved one.
