Yeah this is the way i'd do it , as said deffo a mask tooDepends how thick the rust is and how thick the sheet is?
I would use an angle grinder with a cup type wire brush - or a flap disk. Be warned - I have burnt out an angle grinder doing that - it puts a lot of load on it!
I have done 2 big welding tables like that. Takes a while - wear a mask - and do it outside![]()
This is by far the best option if possiblesand blast......there's always some firm locally....if ur not in a rush it'll be beer money.
That is why I asked about thickness. Not good on thin sheet. Also depends on what surface finish he wants.sand blast......there's always some firm locally....if ur not in a rush it'll be beer money.....
My ol mate would have charged a tenner for that size and it would get a decent primer coat as well....
He's now in Ozz.....lucky lad....
Not always. Thin sheet will warp and surface finish may not be acceptable.This is by far the best option if possible
that's got to be the daftest idea of the dayIf I was going to do a biggish sheet like that, I'd try a petrol strimmer with a wire wheel.
Obviously super dangerous since they're designed for pavement weeds etc. but you'll be the length of the strimmer away from the action.
To be fair people aren't back from work yet.that's got to be the daftest idea of the day
Why? It would probably workthat's got to be the daftest idea of the day
They really aren't that bad. Mind you I have a big brush cutter with a harness and cow horn handles.I have seen those and I can imagine how goosed your arms would be trying to control a rotary wheel held a metre from your body. It's hard enough to use one on a 9" grinder.
Not to mention the stress it would put on the strimmer drive train.
