OK, I'll let you know what I find. Do the same procedure I guess?Now put the leads on the dc side and see what you get -
Just goes pop-pop-pop! (Not a porous crackle but a pop).Hmmm - should be working , voltages a tad low but not to bad
If it’s still like string then need to be looking at bad connection somewhere
Yeah, tried that, no difference. It did occur to me it could be dirty wire but no.Try a new reel of wire?
Many hereI'm not I just want to get on with the car!
would buy a new/cheap/disposable, superlight inverter mig & crack on with the job, then come back to this one to fix at leisure...Yeah, I think I light have to, bloomin thing. I'll try another earth cable tomorrow and see if that makes any difference. It's almost like the wire pushes the gun back due not being earthed properly a few seconds later it's fine again!Many herewould buy a new/cheap/disposable, superlight inverter mig & crack on with the job, then come back to this one to fix at leisure...
Then you'd have a nice portable backup mig once the butters lands the right side up...
Yes, the bottle ran out a few days ago and I thought, oh it was that after all! It wasn't.presume you are getting gas at nozzle ??
Yeah, only happened on initial start or a flashed up on the meter intermittently. I had a quick look through that guide, I shall try, if I can get my head around that.Those high open-circuit DC voltages - 35v, 64v, and 80v - in switch positions 1, 2, and 5 are strange.
I tried to replace diodes in one a few years back and it still never worked after doing it so I'll replace the whole thing if necessary.I had to put new diodes in one of these a few years back , changed all four, worked a treat afer , all though only one was duff at the time.be carefull with the insulators when reassembling , some what fragile
The multimeter does not give reliable results with such a measurement (it is a voltage with strong ripples), it would be necessary to load the outputs of the MIG meter with a light bulb (classic, not LED), e.g. 230V/100W, and then the results would be closer to the truth.Those high open-circuit DC voltages - 35v, 64v, and 80v - in switch positions 1, 2, and 5 are strange.
I've started suspecting the gas solenoid is sticking and "getting lazy" not as snappy open close as I remember. A mate has a spare so I'll try that, I had dismissed it being a gas issue a few days ago but maybe I'm wrong. I'll fit and go from there. If still no joy Les from Yorweld (I think it was) has offered to test the rectifier for me.The multimeter does not give reliable results with such a measurement (it is a voltage with strong ripples), it would be necessary to load the outputs of the MIG meter with a light bulb (classic, not LED), e.g. 230V/100W, and then the results would be closer to the truth.
Two of the internal bearings were a little sticky but once I'd worked them a bit the move freely now. The wire feed should be a little smoother, it wasn't bad but I'd say it's better than it was. I hope I get get some more life out of it yet!Ta for that. I'll try later later on. I fitted the new gas solenoid with no change, I was hoping it might have made some difference at least!You said you couldn't stop the wire with a glove on ,you should be able too stop it ,try slackening the drive roller adjustment until you can stop it then tighten a half turn .
One might think that the smaller wire would try to kink and bunch up in the larger liner, but as you previously said you couldn't stop it feeding by hand that would suggest it isn't being restricted.I collect a used MIG tomorrow, used my Butters tonight and it did behave itself. It must have heard about a possible replacement!
Here's a question for you all though,
"Would running .8mm wire through a red 1.0mm liner cause any possible problems?"
I shall have to see how I get on with the used one but at least I should be able to get on with stuff by having a 2nd machine.
).Hi, interesting. You mean this "block", right? I can't find a higher resolution pic of it at the moment. Would it be worth cleaning in IPA or just replacing? If a transformer for example surely it would work or "not work" and nothing inbetween, would it? I did check those connectors were tight but for the contacts themselves, I have no idea. Ta!One might think that the smaller wire would try to kink and bunch up in the larger liner, but as you previously said you couldn't stop it feeding by hand that would suggest it isn't being restricted.
I'd have one eye on an intermittent contact, probably in the contactor - it might be closing the contacts and allowing sufficient current to flow in the primary that produces the voltages you see in the secondary, yet under actual welding load the contacts have sufficient resistance that the transformer can't pull enough current and the secondary voltage falls off... leading to the spitting and spluttering. Every once in a while the contacts might close on a 'clean' patch and it starts working OK.
Might not be that, of course, but I have seen it happen. At work I maintain mag particle inspection powerpacks and they have pretty much exactly the same internals as a MIG set minus the wire feed (but output up to 6000A).
