angellonewolf
- bristol england
I've had a phone mount thing in my van for a few years. It has wireless charging and holds the phone.
That's about all I want it to do.
The usb socket has eventually failed so I bought a new one...
£14.50. First one I found, didn't look to see if I could get the same thing cheaper anywhere else.
Arrived. Quality was better than I was expecting. Not that I was expecting much but the plastics are decent and the mounting clip is metal rather than plastic. Came with 2 different length usb cables.
But, it does a bit more than I was expecting. Wireless charging coil that supports both charging speeds.
14 led lights all different colours (that you can't see when the phone is in place)
But also, the brackets/grips that hold the phone are motorised. There are optical sensors in the cradle that open the grips when you hold the phone towards it.
Once the phone is in there is a touch sensitive button to release them.
They have some sort of torque sensor so they stop once any width of phone is gripped.
There is a second touch sensitive button.
This rotates the bracket (powered again) 90⁰ into landscape mode.
Pressing the release button when it's rotated automatically returns it to the upright position before it opens.
Not only all of that but it also has its own internal battery that powers everything without it being plugged in!
Obviously I'm part of the problem as I didn't pay any attention to what I was getting and bought the cheap cr*p in the first place.
But what a lot of tech for the money!
I'm expecting it to be in landfill within a year or so as there is no method of releasing the grip manually...
Perhaps I'm just this way but all ways thought loads of extras made cheap and more to go wrong
This In my car bought 8 years ago a metal plate stuck to the phone case this to the vent
Holds well(or used to due a replacment realy but yse the car only a bit now days)
If you want to charge plug and cable in
