Last year my garage burned down due to an electrical fault. 95% of the contents was lost and they have just started rebuilding.
Once the new garage is up I would like to buy a milling machine and a lathe. Previously I had a Warco bench drill which covered most of my needs. Unfortunately, to buy the same machine it now costs £350 more. Which made me think, if I could also drill with the mill.
It is only used for personal projects, so even if it all takes a bit longer it makes no real difference. Hole sizes vary from predominantly 10/13mm to 25mm or 34mm with a hole saw.
The material used is all mild steel or aluminium. For the larges sizes I was using blacksmith drills but the mill will also take mag drill cutters.
Would a mill be able to meet my needs?
