carl0s
- Kelsall
Hi all.
I've been wanting to do my own tyre changes for a while, so I picked up a used Bosch WBE 4110 dynamic balancer. It was advertised as faulty due to a certain error code, which I found to mean an optical sensor / photodiode fault. So I bought it on the basis that I might be able to fix that.
Got it home and no such error, seems to work fine.
I balanced my known-vibratory 1 series front 18" wheel and it was much better, fine in fact. This was about a year ago. Other things have happened since (g/f engine spun 5x rod bearings) and so my tyre changing project has been on hold until last weekend when I got my garage back and built the manual tyre changer + adapter / modifications.
I have this issue with the Bosch balancer though and am not confident it's right. It might be that I'm using it wrong, although I think I'm doing it right.
The issue I have is that it tells me to put 30g on the inside. I do that, then spin it up again, and it tells me to put 20g about 30 degrees anti-clockwise to the 30g that I just put on. Then I spin it up, and it tells me to put 15g about 30-degrees anti-clockwise to that too.
Isn't the idea that it gets it right first time? I did my mum's wheel today and after about 3 or 4 lots of loading up weights, it says it's balanced.
Any tips? I haven't attempted a calibration. I suppose I should at least calibrate the spindle. I don't really have a known-good test wheel.
Maybe I should get a static balancer to compare the results? if they're cheap.
