Pigeon_Droppings2
- london
I was always told not to eat green potatoes...if they're exposed to light they turn green.
The spuds greenery sends out shoots /chits when covered over which become potatoes .. the same a straightforward planting in the earth and ridging up .I've these two old what were used as compost bins by the FiL. The taller one is just an undrilled barrel but with a crack so it leaks. The short one with holes in has the bottom cut out - pictured upside down.
I could cut one in half.
How then do the spuds grow if I stick a barrel over one of the tall plants and fill with soil? From the covered foliage?
Yes you do or used to see farmers doing the initial ridging and a second or some times even a third ridging up to the top of the greenery .I've said it before, but i don't get all the mounding up potatoes malarkey. Yes I understand that they will crop further up the stems and possibly be a bit more productive, but from my experiance it just isn't worth the hassle, and you don't see farmers going round earthing up fields of spuds.
If your that worried about yield, shove a couple more spuds in per meter.
If I was you @Onoff I'd just leave them too it (maybe a feed with some tomato feed or a sprinkle of chicken manure) but as long as the tubers aren't breaking the surface just let them do their thing. You'll still get spuds off them, just maybe a couple less.
True they contain cyanide but as far as I know haven't killed anyone as it is such a low dose .I was always told not to eat green potatoes...if they're exposed to light they turn green.
Once you get potato apples it usually time to lift them as they come a few weeks after the potatoes flower when the conditions are right . You can use them to make seeds but it take several years to get a viable seed and you cannot grow them in previously used potato bed areas due to potato diseases susceptibility .A few of my potato plants seem to be growing something from the flowers:
Presumably these aren't any use for anything. Do they signify something I haven't done? I don't recall seeing this before. Ironically they're more productive than the tomatoes that I've been trying to grow elsewhere.
Separately, my Pyrocantha has a lot of these on it. Are these going to turn into the red berries later, or are they just dead bits that I could trim off?
It's got a bit overgrown, alongside a very overgrown buddleia, and I'm trying to trim both of them down. The buddleia is doing a fine job at shielding the living room from the sun (and most daylight, as it goes) so it's been helpful during the very hot weather, but the pyrocantha starts to grow really spiky things all over the place.
Keeping slugs & snails out might not solve the problem till you exterminate their eggs in your bath tub .
I suggest you think of using a slug ( Found in nature so as natural as can be ) nematode to get rid of them , follow the instructions exactly & use a fine rose watering can to apply them , as well as use up any left over mixture around other plants .
Two applications of slug nematode saw my beds slug free of four or so years
This year because of other problems & commitments I have let my raised beds go feral whilst I'm doing other major works & caring for my lass who was suddenly stuck with level 6.5 MS last year & is struggling with it this last year.
Where's the yuk emoji?My neighbour has an old bathtub full of snails he’s raising to eat![]()
My daughter grew 2 inch dia .African snail for several years till one day they suddenly snuffed it , OMG what a stomach churning stink .My neighbour has an old bathtub full of snails he’s raising to eat![]()
Had some French escargot & frogs legs whilst over there .. Snails utter pap with too much garlic, frogs legs similar but they were swimming in garlic & tomato gravyWhere's the yuk emoji?![]()
Quite, I don’t see the point in eating something that you have to drown in garlic to make it edible.Had some French escargot & frogs legs whilst over there .. Snails utter pap with too much garlic, frogs legs similar but they were swimming in garlic & tomato gravy
I tried them...they were ok taste wise but 30mins later I was sprinting back to my hotel room! Undeterred I gave them a second try...same result so never again!Had some French escargot
Fastest a snails ever moved.I tried them...they were ok taste wise but 30mins later I was sprinting back to my hotel room! Undeterred I gave them a second try...same result so never again!
Yes for small plants .
Not sure about your gangly big plants . Why not cut the bottom off a plastic bucket invert it over the tall plant and fill to the rim with soil perhaps, post the result in September , don't over water though & they would benefit from a Tomorite feed as you have chalky soil which will see loads of essential nutrients drain away when it rains .
I’d have a rethink on adding diseased/pest infected material to your compost. Do you get the garden waste bin from the council, if so chuck it in that, or maybe the ordinary binSomething broke the flowery bit off of one of my potato plants. Does it matter, will it die?
Then my Czar runners. Some look decidedly unwell. Seems to be a few plants on the shaded side. I'm removing these and putting straight in the compost bin.
Others have very occasional, almost pin prick like little warty spots, see by my thumb:
Others look just a little stunted and curling up:
