Folks.
As I'm far too old to crawl under the van to get to the spare wheel in the event of a puncture, and I can't carry it in the van as I'm converting it to a camper, I'm in the process of making a dual swing out carrier to mount on the towbar of my Transit Custom, spare wheel on the nearside and extra storage on the offside. The main "frame" will be a full width length of 4"x2" box section bolted to the towbar with two half width lengths of the same on top that pivot from the outside, like so:
For the pivots I acquired a pair of trailer hubs and spindles, the plan being to slot the ends of the lower box and weld in the square shank of the spindle, as per the r/h side of the photo, then notch the outer ends of the upper boxes and weld on the hubs, after machining the bolt flange off, all finished off with locking latches. I took the tow ball off because I don't tow anything with the van, and the combined weights of the carrier and spare wheel are still well below the maximum permissible weight for the bar so all is good in that respect.
After what feels like years spent machining the hub flange off on my little hobby lathe (anything more than a few thou stalls it...) I'm wondering what metal it's made of, here's the cuttings, and for reference the wood with the chalk "x" is 30mm wide:
As well as not being sure how it will weld to the steel box section, I'm also wondering if I'm over thinking and over engineering the entire pivot assembly, so if anyone can suggest a simpler method, I'm all ears. In all probability it doesn't need bearings, so what seemed to be the "right" style of pivot now seems over the top. Instead of a machined hub, would something as simple as a steel boss with a nylon liner suffice
Thanks, as ever.
Martyn.
Thanks, as ever.
Martyn.
