Guineafowl
- Nairn
No matter what I do, it keeps pulling apart at the pivot. It’s not been used for a long time, and I’ve never hitched one up before, so not sure if it’s busted or if I’m doing something wrong.
Has that snapped or come apart at the bottom, looks to me like that should have a bearing or some kind of top hat bush/ bearing at the top.No matter what I do, it keeps pulling apart at the pivot. It’s not been used for a long time, and I’ve never hitched one up before, so not sure if it’s busted or if I’m doing something wrong.
Will do, thanks. I’ve only ever used in-line toppers and flails before - what’s the best pattern for covering the field?In future once you've repaired the headstock, undo the balance springs from the top before unhitching, it'll let the headstock sit flat and makes it far easier to hitch back up again.
We have an am240cv as well, they're great mowers.
We use ours for silage. 9-10 times right around the field. Then split it into 2 or 3 bouts, work the insides outwards by going anticlockwise, then when the bouts are half gone, go clockwise around each bout to finish. It minimizes the tracks at headland.Will do, thanks. I’ve only ever used in-line toppers and flails before - what’s the best pattern for covering the field?
- Round the outside once with the mower on the outside.
- Spin round and do 3-4 more rounds with the mower on the inside, till the corners go wonky.
- Go up one side, lift the mower a bit and go all the way to the other side and down that? Or strike out a path down the middle, then what?
Thanks!We use ours for silage. 9-10 times right around the field. Then split it into 2 or 3 bouts, work the insides outwards by going anticlockwise, then when the bouts are half gone, go clockwise around each bout to finish. It minimizes the tracks at headland.
We'll only drive around the field once or twice before having to lift up at corners, reverse and drop in at a true 90 degrees.
also , IMO the best thing is to leave the outside run (against the hedge) to the very last. That's where you'll most likely hit rocks, stuff that's been put against hedges, etc.Thanks!
Done the field now! A few more questions:also , IMO the best thing is to leave the outside run (against the hedge) to the very last. That's where you'll most likely hit rocks, stuff that's been put against hedges, etc.
As opposed to my dad who likes to get the outside run done after 3 times around, as he can't stand leaving it untouched![]()
Yes to float position, if you have it handy, but its not essential. Once it's dropped into work and link arms are at the right height, the mower pivots and contours on a 4 bar linkage.Done the field now! A few more questions:
- When you drop the mower down to start, do you leave the lever in float? Eg I pull the lever back to drop it, so do I leave it latched in the back position when mowing?
- Travel speed? I was going maybe 7 mph (low 3rd on JD 2650). Felt a bit slow for stalky, unfertilised grass.
- My PTO has an ‘eco’ mode, basically higher-geared so you can have lower revs for the same PTO speed. The conditioner part is disconnected, so would I be ok using that? Seemed to do ok on a test pass.
