Really? That’s not quite as reassuring as the other postsI've got some puddle welding rods but you'll definitely need oxygen acetylene for those and I think there's a special flux
That may be a true statement.Really? That’s not quite as reassuring as the other posts![]()
Yep. My only options are arc, (maybe) brazing or JB Weld. Oxy and TIG are no-go cos I don’t have it and the cost isn’t warranted.Lol, as usual, so many ways to solve the problem it presents a problem of it's own...
The trick is to separate the pro's from the have a goers, before seeing if you have the kit the pro's suggest you use...
Carbon arc brazing attachment for an arc welder would work, but it can be messy and awkward to use due to their size/design.Yep. My only options are arc, (maybe) brazing or JB Weld. Oxy and TIG are no-go cos I don’t have it and the cost isn’t warranted.
TBH that is why I posted this in the arc section….
Thanks. Let me check as I have a vague recollection of buying some ages ago.Skotl I have some Nickel rods that I have used to some success on cast iron , usually involving some preheat and some sand to let it cool down slowly.
Would you like me to pop some in the post for you to play with .
