Hello all,
Just a quick question more as I'm about to pull the trigger on getting an oxy tank to go with my propane tank, and will then require gauges, flashback arrestors and check valves etc.
Does anybody use the resettable flashback arrestors or am I being OCD wanting to be able to check their function before using the setup?
It will sit in my garage for a while and just gives peace of mind that things still work when I go to use them with months in between.
The ones I posted below look good, but maybe too good to be true as they're *relatively* cheap to compared to others.
WDYT? What's the general consensus on flashbacks?
Cheers
Cheers
tighten em back up reset them check for leaks and away you go . they have tripped twice in use over 50 years ,
