hotponyshoes
- Somerset. Uk
I have a piece of vetinary equipment, this has an output to run an external peristaltic pump.
It has a small pump at the moment and that needs changing for a bigger one.
I'd guess the small pump is pulling 2 amp (probably quite a bit more at start up) and the bigger pump maybe 6 amps.
Pumps are 24v dc.
The machine outputs 0-25v dc. 0v is off, then it starts at about 11v and varies the speed between 11v-25v.
If I connect the bigger pump to the machine directly I get a 'pump failure' error when I try to start it and it cuts power to the pump.
If I remove the tubing from the bigger pump (so no load) it works fine.
There are only 2 wires that run directly to the motor so there is no speed sensor or anything at the pump end.
I guess there is some sort of load/current sensing inside the machine giving the error as it thinks the pump is blocked/faulty.
I don't really want to open the machine up and start fiddling with things to see if I can bypass the error somehow and I certainly don't want to burn out anything by overloading it.
So, is there some sort of 'amplifier' module I can use externally?
Something that will take an input of 0-24v and give a higher current output at the same voltage?
Pumps are 24v dc.
