Green Bean chutney is lovely alongside a good curry with a few poppadoms and a cold pint. Add a few chilles to the recipie if you like it spicy.
Runner bean chutney recipie
Hmmmm, good spot. No idea what I was doing there, and I hadn't even been drinking.I think that might be the wrong link, unless the chutney also has roadkill in it.
Pull the biggest leaves each day and you'll likely be able to use the same plants for the rest of the season. I managed to grow a single 19 inch diameter Lollo green lettuce in the shade from a 2 inch high transplant out of one of my bottomless seed growing tubes ..no root disturbance at all so it grew exceedingly well for our family of three . It grew from early spring right through till first frost. Fed it a few times in the ground and as a foliar feed with Tomorite and sea weed extract. & used a lot of slug pellets to keep the little bug-gers at bay
Sell them to a vegetarian, go to butchers and buy steak!Apart from the obvious answer. Does anyone know what to do with these.
Or more specifically, has anyone got any recipies for them, or know how to cook them?
It's a summer Squash, (White Scallop) and for context it's about the size of a dinner plate.
I thought I'd plant a couple in my compost bin as a bit of an experiment, along with a normal Pumpkin, but they appear to be taking over the world, and having grown them, I've no got idea what to do with them.
If anyone's got a recipie or idea on how to cook them, I'm all ears.
I'm on blight watch at the moment...I think it's hopefully just missed us fingers crossed!I have plenty of flowers on the various tomato plants
Each day around the warmest time gently tap the branches with open flowers on them starting at the top .. what you'll be doing is putting a heck of a lot of tomato plant pollen in the air . Toms tend to be able to self fertilize by this method.I've found now that I've been able to harvest leaves from some lettuce plants, in fact this week is the first for a while that I haven't bought any, and I've just been out and got a few more, enough for a couple of days. That's a mixture of a few out in the garden under wire hanging baskets, and three in a small tray in the lean-to greenhouse. The seeds I planted to replace the other ravaged plants haven't done anything yet.
I have plenty of flowers on the various tomato plants, but so far only one actual tomato. Similarly the chilli plants have some flowers, but nothing else.
If they are in the glasshouse , put a fan near them to provide air movement .. blight in toms loves still high humidity .I'm on blight watch at the moment...I think it's hopefully just missed us fingers crossed!
You can use them to thicken up stews & soups , add them to salsa and ratatouille .? Check BBC Good Food recipes they tend to have been tried by qualified cooks and use British standard measure & weights . of ounces or gramsApart from the obvious answer. Does anyone know what to do with these.
It usually starts at one end of the allotment...couple of weeks and all tomatoes are gone. I think I've been trying for about 5 years ...ends badly every timeblight in toms loves still high humidity .
www.homesandgardens.com
Our local farmer is heavily into growing potatoes.
Are you practicing pruning your vines so you only get say five clusters on the vines height then pinch out the growing tip .
You also need to pinch out new growth between the main stem and a branch where a new shoot appear to stick up like a chickens middle toe . If you don't know what I'm saying see if you can find a couple or trio of YouTubes on it , compare them to what I've said and use what you think is best practice.
Leaving excessive greenery & not pinching out the middle claw robs the plant of energy to produce them which should be better used to produce fruits
I've never had much luck growing food plants in pots...they never seem to take off in the same way as putting them in the ground. Could be that I don't know what I'm doing of course!They're in pots, in new compost, even the three plants I've put outside are in pots.
