whats your pointmystery,is this common,we’re sinking a water pipe for our new campsite,came across this,it’s dead alright! 350mm below,this is flooded every winter at least once.View attachment 501991View attachment 501992
.When cutting into serious (11k-34.5kv) underground lines (on purpose)Cut it and see what happens ?![]()
it's really, really important that the line is checked as dead.
Last thing our guys do before cutting the cable, is clamp a device on the cable, and remotely fire off an explosive device that drives a nail into the cable.
Thereby shorting the center conductor to the grounding shield wires on the outside
of the cable.
Yes, that was my thought too.If not it's the supply earth to the transformer.
I remember those too. The ones we had (SWEB area) used a blank ammunition cartridge.Called cable spiking in the UK - link
Not insulated.Hard to tell, but is it insulated? If not it's the supply earth to the transformer.
IIRC for a rural pole mounted transformer there would be separate earth electrodes for the HV side (usually 11kV) and LV (415V) side.
These would be physically separated (ie run in opposite directions for example).
Just leave them be and ensure that there are buried when you've finished.
They were clamped over the cable, armed and then fired by pulling a string from a suitable distance.
May sound daft but quite often in urban areas there were several cables running in close proximity and at the bottom of a newly dug muddy pit it could be difficult to identify the one to be worked on.
Additionally the records were not always accurate so the cable spike gun was often before opening up a cable to make a joint or repair.
