keithski122
I've decided my beetle needs to be bare metaled and resprayed.I high build primed it before and 2 pack painted the top coat but a lot needs redoing.
My plan is to strip it bit by bit, coating it with aerosol primer for basic protection against flash rusting, then when a panel is done wipe/sand the primer off and epoxy prime it.Then filler work, followed by 2 pack high build then 2pack colour, either solid or base followed by clear.
Now, how workable is the epoxy?
If I should scrape it or spill a bit of paint striper on it(while working on it) , can it be flashed over? Its going to take a while to do and I've read that epoxy is virtually bullet proof, can I just DA over it with something like a 180 disc before high build or will it need more epoxy?
Any other tips?
Any other tips?
