The_Yellow_Ardvark
https://www.death-clock.org/
 - Going Away.
It's future is not known.Nice old tool but what do you do with stuff like that?
Do you sell it on to a collector?
Initially I was trying to work out what was so special about an Indesit washing machine simply in need of a damp rag dragged over it . . .Nice old tool but what do you do with stuff like that?
 AIn the last couple of weeks I've managed to wash my watch and the printer fob attatched to a lanyard from work. Amazingly both still work, as does the washing machine. It wasn't that long ago the my Airpods went through the wash too.F05 fault on the washing machine. Of course it's always my fault and tbh it usually is a nut, bolt, Pound coin or some random fixing.
Girly stuff, powder puff?What was blocking the impeller?
	Was it parked at the bottom of a lake?spent a bit of time on making the rust monster that i bought with a locked engine a couple of weeks ago run today.
but first, rust photos...
so having checked the oil and water, cutting the ac belt off to free the engine and rolling it over by hand, i chucked a new starter motor in. i think you can see why...
found the battery to be absolutely stone dead
(that's my 12v-12v optimate in recover mode)
chucked a jump pack on it and...
idles nicely
that is genuinely the first time that engine has been started since 2013. 12 years idle and it started like it was switched off yesterday.
then the obligatory hot start.
and drives perfectly.... as long as you remember no brakes...
As I started to read the bit between the pictures…..my initial thoughts…were rebuilding the front of the stable!Technically yesterday but finally got around to mucking out the stable using the quick method... Didn't have quite the reach to get in all the corners so still a bit of manual labour for some exercise.
Then the rest of the day was spent reassembling the front end of the Range Rover as the 110 has started making nasty (internal sounding) noises.
Not quite, it got close but didn't do any permanent damage.As I started to read the bit between the pictures…..my initial thoughts…were rebuilding the front of the stable!
The trailer didn't like the load unfortunately...As I started to read the bit between the pictures…..my initial thoughts…were rebuilding the front of the stable!
the rest of the machine looks new! As though those cylinders came off something else!Looks like new.![]()
