When I put the twin four barrel tunnel ram on this everybody told me it wouldn’t run smooth, wouldn’t tick over below 2000, wouldn’t pull properly until 5k rpm etc. The carbs were 600 Holleys, with vacuum secondaries.One of the biggest problems with over carbing is the lack of velocity in the charge to keep fuel suspended/atomised. A mate of mine built up a mildly tuned 302 ford for his Cobra, all the advice given was to go with a 650 cfm four barrel double pumper, only ever ran properly when the link bar was removed on one set of butterflies, in effect turning it into a two barrel carb.
Bob
I managed to set up the fueling on my locost with a 1600 Xflow converted to full Emerald engine management pretty well so that I could get a few miles on the engine before the car went on the rolling road by driving the car at a steady speed and throttle opening while my brother adjusted the fueling on the laptop. It helped that the ECU has a built in gas analyser and throttle load/speed indicator. Dave Walker set it up for me and complemented me on the initial set upNot so sure you could ever get an accurate reading without holding a steady state engine load like on a dyno, touch the throttle and in goes a load of fuel from the accelerator pumps.
Bob
He managed to set my car up pretty quickly fortunately, I would hate to have had to have paid for 3 days on the rolling roadI spent three days with with Dave on his rolling road mapping an engine with one of his ECU's, he knows his stuff or did do, I believe Carl runs the show know, they have come on a long way in the ECU world.
Bob
The venturis are 26 and 27mm, is that good or bad?If you look at the Weber literature, I think you'll find that for any specific model, the throat size (i.e the diameter of the outlet at the base of the carb, so 32/36mm in your case) is fixed but there may be a range of different sized venturis on offer. The venturi size is usually indicated by a number stamped on the body of the carb like 25/250 (it's not a dimension, just a "type number" and the venturis could be something like 25/26mm, appreciably smaller than the throat ) and it would be good to check that you have the correct venturi size for you car.
I disabled the accelerator pump.Not so sure you could ever get an accurate reading without holding a steady state engine load like on a dyno, touch the throttle and in goes a load of fuel from the accelerator pumps.
Bob
Yes I did all that.Is the ignition perfect?
Improper combustion will cause the O2 sensor to give misleading results.
The SU is the most common swap. The manifold needs to be modified, it has coolant jacket inside so not sure how easy that is.A friend of mine fitted 1.5" SU carb to his SJ410. It took some experimenting with needles but it ran better than the knackered original carb.
No, competitors. And the range of jets for Dellortos is much superior, probably why the Italians used them for their sports cars...Were dellortos not just a copy of a weber?
HereOn the Weber website, searching for 32/36 DGV brings up this page https://www.webcon.co.uk/shopdisplayproducts.asp?Search=Yes&sppp=20&page=1&Keyword=32/36 dgv&category=ALL&highprice=0&lowprice=0&allwords=32/36 dgv&exact=&atleast=&without=&cprice=&searchfields=
I think all the kits on that page are for engines between 1.6 and 2 litre.
I don’t see your kit on that page, but is here https://www.webcon.co.uk/shopdispla...exact=&atleast=&without=&cprice=&searchfields=
I think you need to ask Weber about whether the 32/36 DGV does come in models with different venturi sizes, and if so, how do you confirm you have the right one. On the Webers I’ve used, it’s given by a number stamped on the mounting flange.
Weber uses long product code numbers in their catalogue for different kits, and that number used to be shown on the box the carb came in, but I don't recall it being on the carbs themselves. The correct kit for you is product code 1887099005 according to the second page above.
The last Weber I worked on was a twin-choke model 34DMTR, and that was available with 3 different venturi combinations; only the number on the flange confirms the suitability for a particular car.
I'm reluctant to speak to Weber as they clearly cant be trusted and the carb I bought is exactly the one they list for the car with matching Venturis and correctly incorrect jet sizes. It seems obvious now that the 32/36 is overkill for a 1.3, and they probably sell it for the 1.3l is as it's just a universal go-to carb.On the Weber website, searching for 32/36 DGV brings up this page https://www.webcon.co.uk/shopdisplayproducts.asp?Search=Yes&sppp=20&page=1&Keyword=32/36 dgv&category=ALL&highprice=0&lowprice=0&allwords=32/36 dgv&exact=&atleast=&without=&cprice=&searchfields=
Thanks, that gives me a good reference point. My spare Weber 32/32 has 23 and 24mm chokes so seems more suitable.I have the John Passini books, the 28/36 (not quite the same I know)was used on 997 Anglia's so I doubt that it's oversized for the application.
If you want any info from either book I can copy and send to you.
EDIT just had a quick look, 1200 Anglia used 23 and 25 chokes. Yours looks to be a good bit bigger.
I checked out the Webcon site when looking for a basic 38mm Weber for my trike bolide. What would cost me £400++ from Webcon was £83 from China, on EBay. I took the plunge, just for a laugh, expecting to get some cheap tatt for my money, but what arrived ‘appeared’ to be a very good replication of the original carb. The finish was excellent, everything fitted neatly, screws and various parts were all tidily fitting etc, but I never ran it so no idea about jetting etc.Here
Fixed venturi![]()
WEBER 32/36 DGV CARBURETTOR CONVERSION KIT | SUZUKI 413 SAMURAI / SANTANA - Classic Carbs UK
Complete Weber carburettor conversion kit for the SUZUKI SJ 413 4x4 1324cc engine.classiccarbs.co.uk
No mention of which float height
Lol yes I was thinking of doing the same, they were so cheap I considered buying one just out of curiosity. I've heard that the fake carbs can have things like porous castings, but that could have been sorted by now, some great stuff coming out of China now.I checked out the Webcon site when looking for a basic 38mm Weber for my trike bolide. What would cost me £400++ from Webcon was £83 from China, on EBay. I took the plunge, just for a laugh, expecting to get some cheap tatt for my money, but what arrived ‘appeared’ to be a very good replication of the original carb. The finish was excellent, everything fitted neatly, screws and various parts were all tidily fitting etc, but I never ran it so no idea about jetting etc.
So no coolant in the manifold at all? I always imagined that when the SU flange is welded on then a welder could reach inside enough to create a seal.I got a suzuki manifold modified to take an SU carb. Pretty sure the coolant jacket was blocked off and the hoses were joined together with copper pipe. I also have memories of a Subaru carb being made to fit
None that I can remember.So no coolant in the manifold at all? I always imagined that when the SU flange is welded on then a welder could reach inside enough to create a seal.
