Bravheart
"Tomorrow will be a good day"captain Tom1920-2021
- Scotland
Inside of control box just power off/on and stop start buttons on the front. thanks.Are there any controls (eg relays) associated with this motor? If so then you need to make sure the control voltage is suitable for these as well, a vsd typically won’t be suitable for these.
For that motor it looks like you need a 230-380v vsd unless there is some links inside the terminal box to change voltage.
Buy a Chinese VFD with minimal documentation. They won't mention that it is not suitable for an compressorIf I can hijack the thread for a moment please...
I was surprised to see that the realistically priced VFDs claim that they can't be used with compressors, which is what I need. £3k for a rotary converter is not an option, I can replace my three phase with two single phase compressors for less than that.
Keep an eye out for secondhand rotaries - there’s an 11 kW one near(ish) me for £1100 at the moment.If I can hijack the thread for a moment please...
The big issue with ramps (and compressors) is the startup.
When connected to the mains, the motors spin up quickly which means they're pretty much at speed before the pump starts loading the motor.
A typically sized VFD can't supply the same surge current as the mains, and rely on accelerating the motor relatively slowly, which means the pump will often stall the motor before it gets upto speed.
To get around that, you either need to oversize the VFD, or remove the pump load until the motor is at normal speed.
I see your semicolonThank you. The compressor is this one: 3 phase compressor... And I have been starting it remotely with a power switch for convenience; the motor never stalls under the load.
On a normal run of the mill compressor the unloader valve is usually part of the pressure cut out switch (i think) - and simply vents to atmosphere when the pressure switch kicks in (it’s the hiss you hear when the compressor cuts out on reaching pressure) but it only allows a very short start up time so probably not enough for a vfd to ramp up.I was under the impression that something called an 'unloader valve' is available for a similar situation. It allows the motor and compressing bit to spin up to full speed before it starts squirting air into the tank. I guess it is similar in principle to a decompressor on a hand start diesel engine.
I wonder if something as simple as a solenoid valve on a timer would work. Vent the comporessor to atmosphere for five seconds after power is applied and then let the valve close.
The motor label states "thermal protect".
