Agreed, as I pointed out earlier. Flat back the Jotun and lay a couple of coats of an automotive epoxy.
I better buy myself a compressor and spray gun
or what are the other people that do these by hand using? maybe theres some primers that lay down smooth with a roller
I was watching "How they do it" the other night....they were building a huge super yacht.Depending on how bad the orange peel is but you could spray on a few coats of a 2k filler primer over the epoxy and then sand that smooth.
You only really need 1 or 2 coats. Epoxy paints like this have specific overcoating times. Ideally you apply a suitable compatible topcoat within that overcoating window. If you miss it you have to wait some time and then sand back. Much better to plan the painting and overcoating together. That way you get a chemical bond. when that window is passed you need a mechanical bond.Morning all,
I’m looking for a bit of advice with regard to an orange peel finish. I’ve primed by narrowboat with Jotun Jotamastic 87, this was rolled on due to time constraints and the fact that laying off with a brush really didn’t appear to provide a better finish. The boat has had three coats of primer which has left an orange peel texture. The plan is for 3 coats of undercoat, followed by 3 coats of topcoat. I plan to spray this using an airless paint sprayer. As the Jotun is an epoxy based paint it’s difficult to flat with sanding discs, these clog pretty quickly and this clogging is then spread to the surrounding area, might this be that it hasn’t dried enough in two days to cure properly?
Having no experience in painting a boat I’m unsure as to how best to proceed. Will 6 coats of sprayed paint leave a smoother finish or will it amplify the orange peel. Should I attempt to flat the primer before the undercoat, or flat it after the undercoat. I’m expecting some texture in the final coat but would like this to be reduced as much as possible. Any advice would be greatly received.
Mark
