Depending on the length of the cable run a 4mm might do, and also where the output socket is located.Thanks. I'm assuming using 6mm-10mm gauge cable?
It's a workshop about 30 metres from my house. Previous owner put a 2.5mm swa ring in it from the consumer unit, which is obviously underpowered for my purpose.Depending on the length of the cable run a 4mm might do, and also where the output socket is located.
Is it in a garage/workshop integral the building with the fuse box or a seperate building, this would have a bearing on the type of cable required for the installation?
A so 32 amp breaker in the house CU feeds a small fuse box in the workshop.It's a true ring main alright!
Unusual as it is. 32 amp from the CU and a small fusebox in the workshop on a 32 amp switch. It's my workshop, but it was more of a shed/garage for the previous owner.
Yes, no bother at all.Hi.
Could I run the ESAB rogue 210 Pro off a 32 amp commando plug, connected to a 32amp mcb on a 2.5mm twin and earth ring?
Looking to mig weld 0.8- 1mm steel for a project.
TIA.
I agree that it could be used at less than maximum ampage on a ring main, but we all know that at some point that dial will be turned up to max, why because we have all done it at some point .Yes, no bother at all.
Not sure what all this hand wringing is about by other posters. You have the right size ring main wiring protected by the right size MCB.
It might trip the MCB at high amps, but very unlikely to be a problem under 150 amps![]()
until the thermo switch went fuzz....
and then into the skip it went...Thanks.A so 32 amp breaker in the house CU feeds a small fuse box in the workshop.
Are the two x 2.5mm swa cables wired into the main breaker switch connections in the workshop fuse box, fed from the houses CU 32amp breaker?
If it's a true ring main you shouldn't/wouldn't have a fuse box in the workshop (the only breaker would be in the houses CU), or is it two (2.5mm swa cables) run in parallel to increase cable core area?
Which possibly might mean the workshop has a 5mm supply cable feed (using 2 x 2.5mm run in parallel)?
@brightspark might be able advise....
PS:-
Pictures of the house CU and Workshop fuse units wiring connections would help no end, but you have to feel capable of removing and replacing the covers on both fuse units safely,
Now here's a possibly if it is a true ring main...Thanks.
I'll take some pictures this weekend.
Now that you say that, I may have been talking ********. I've recently moved in and getting my head around it all. The fusebox may be a waterproof junction box to terminate the swa to normal 2.5mm T&E inside the workshop, and not be fused.
I'm at work so can check till tomorrow. Thanks for the input.
.Thats why the 32a MCB is there, to protect the ring main. It will trip, and nothing will fail dangerously.I agree that it could be used at less than maximum ampage on a ring main, but we all know that at some point that dial will be turned up to max, why because we have all done it at some point .
.Why would it? Its literally why wiring regs exist. The MCB protects the wiring on a ring main. The 13a fuses protect the devices on 3 pin plug sockets. The 32a plugs and sockets and welder cable are all rated for 32a so the MCB protects everything in this case. It's pretty basic stuff.Famous last words..........
Agree, but a lot of members will have a welder/plasma cutter and a compressor, possibly on the same circuit. What happens if the welders/or plasma is on max power and the compressor starts up on load and the trip fails to protect the circuit?Why would it? Its literally why wiring regs exist. The MCB protects the wiring on a ring main. The 13a fuses protect the devices on 3 pin plug sockets. The 32a plugs and sockets and welder cable are all rated for 32a so the MCB protects everything in this case. It's pretty basic stuff.
?????????In that case, install a 16amp socket, slightly better than my 1/4" steel bolt option....The emp210 comes fitted with a 16a plug.
Or a 15a in Europe or 14a in the states.
Just plug it in to anything. Start welding.
You'll be more likely to burn the shed down from the splatter than the wiring.
