hunter27
Pete
- Lancashire UK
Hi.
In my stash of spare stock I had a 75mm diameter chunk bass, I don't remember where it came from.
I bored out a inch and a half hole in it and parted off a 1/2" thick piece. It was not like any brass I have cut before making mainly fluffy swarf not little sharp chips. Parting it off was a challenge but I got there in the end with a really slow feed rate. A couple of times the tip dug in and I had to run an hacksaw blade in the groove to clear the divot which seemed really hard.
Then I put it in my new to me mill and really struggled to drill a 4mm and then a 5mm hole through it, I changed the drill bits twice but that didn't help.
I then had to tap a 4mm thread in one of the holes so I used a first tap and lots of lube and eventually got through but the thread was really tight so I then used a second tap gently with cutting oil back and forth but you guessed it, the tap snapped in. I have changed the design
now still using the part.
I know there are lots of different brass types and was curious to know if anyone could say what it is?
Some bits of swarf from the scrap bin.
now still using the part.I know there are lots of different brass types and was curious to know if anyone could say what it is?
