Melvyn Best
- Cambridge
Isn’t there someone on this forum that repairs ABS modules? I can’t remember who it isI'd be obliged if you could drop me a message with their number, too.
Big nibbling….frowned upon in some circles….My nibbler went blunt today, so I took it to bits and replaced the blunt bit. That was much better, but I think I've stupidly got it too hot and blunted it again. I've left it to cool down overnight and I'll see if I've wasted one of the spare bits.
See if it's a standard bearing and give Simply Bearings a bit of Googlefoo?My mains-powered Katsu die grinder is getting very noisy and rough - I suspect there might be a bearing on the way out. Their web site (AIM tools) doesn't list any spares for it, though I might email them to check. I've had it since 2019 and it's had quite a lot of use, but I'd still rather spend a few quid on a bearing than £40 on a new one, which will inevitably creep up to £50 for the brushless version.
I had exact same on a Renault 16 coming to a halt at a zebra crossing. Luckily didn't hit anyone.Last night, luckily without the lathe on the trailer behind me. Was just about to turn into a mates road where I was having a BBQ last night when my foot went straight to the floor. Cue not pleasant feelings and trying to avoid hitting the car infront waiting to turn into the same road.
A few years ago my ,then 19 year old daughter and three mates set off for an evening "fun" in one of the girls oldish mini. 10 mins later they were back with a " Dad the brakes don't seem very good" I pointed to the oil soaked rear wheel and said that they were not going any further . My daughter then proceeded to tell me that it would be OK as they would take it easy. I took the keys out of the car just to be sure. Kids !I had exact same on a Renault 16 coming to a halt at a zebra crossing. Luckily didn't hit anyone.
I was utterly sure up to that point that the dual-circuit brakes fitted to the thing would have prevented a tragedy. They didn't fecking work!
I am feeling much better about my decision to replace all the brake lines on mine now...Last night, luckily without the lathe on the trailer behind me. Was just about to turn into a mates road where I was having a BBQ last night when my foot went straight to the floor. Cue not pleasant feelings and trying to avoid hitting the car infront waiting to turn into the same road.
Thankfully it turned, a few frantic pumps of the brakes and the LR came to a stop. Waited till it was clear and then pulled up outside aforementioned friends house. One stomp on the pedal by him showed the problem. Burst hardline by the T hence spraying fluid everywhere.
One mole grip later and the flexi was clamped off and I was able to get it back to @8ob's yard that evening. This morning up early and got the broken pipe off, little bit of cutting off pipe with a grinder and hammering on a 10mm socket over the fitting as it was rounded off.
The man, the legend, the Bob himself started making replacement lines and it was all bled and sorted out for the journey home.
The remnants of the brake line after Bob had had his way with them in the workshop
They've held up pretty well given they're the original lines from 1994.I am feeling much better about my decision to replace all the brake lines on mine now...
They seemed fine, but given they were attached to a failed master and 6 failed wheel cylinders...
Could still be repaired, weld a thicker piece onto the spline, spline in lathe chuck and shape same as old piece, then thread the end. It's only a hand powered grinder.View attachment 497597
But.............
Oh well, we can get a new stone.
Oh.......
This can be fixed.
(Bottom, just of centre)
Main shaft is broken, it was the old grease holding it together.
Sad end, but not worth the cost to fix it.
