Hi
I need to modify a cast iron exhaust manifold. The hole circled in yellow needs to move 15mm, to where the yellow dot is.
How do I go about blocking off the hole? A multilayer metal sealing gasket runs directly over the hole, so whatever I use will need to be ground or milled flat. I've got access to mig, stick, or AC/DC tig welder. It bolts right up to the turbo, so is going to get hot.
Thanks
Jim
Thanks
Jim
