Need a bit of advice pls.
Currently they are just tacked in place but I'm welding in some camber and toe adjusters onto my 1987 5 series subframe but struggling with penetration into the subframe. The new mild steel welds ok but the subframe...its like its a tougher steel? The adjusters are 2.5mm thk and the subframe is 3mm thk for reference.
I welded some 5mm thk bracing to other areas on the subframe and had to turn the voltage up to get penetration but then that led to undercut in the 5mm.
Suggestions pls.
Suggestions pls.
