Hey, I have this machine and am wanting to do a few basic tasks.
So this is the manual: https://engweld.s3.eu-west-2.amazon...ts/6427-rogue-150i-180i-manual-1589354941.pdf
I've used it a bit and found it's sticking even though it's not supposed to.
I think I need to use the process selection button, which is the push one used to set hot start and arc force.
Not sure what metals these are but they are both magnetic. I don't want to burn any holes in the thin washer, but I do want it to stick to the rod through the hole in the centre of the washer.
Could someone please recommend settings that are likely to work for this?
I'm also going to need to add some angle bracket to these plates, again the plate is thick but the angle bracket is going to be quite thin.
Thanks for your help! :-)
 Yes — arc blow is caused by magnetic fields distorting the arc, which then disturbs the weld pool. This is more of an issue with DC welding, where the current is unidirectional.
