alexandermarkwinter
New Member
- Nottingham
I am looking to buy either a stick or MIG welder, primarily for welding 10-15mm maximum thickness mild steel plate, it’s non structural and will be under no pressure. But I do ideally need it to be able to run off a standard 13amp plug, I know to weld thicker material you need to be working at around 200amp, and most welders would need to be single phase/16amp plug, so correct penetration can be achieved. I don’t mind pre heating and bevelling and doing multiple passes. Just look in for some expertise on what I should be spending money on. Thank you.
