use 15mm rather than 8mm as u will loose volume using the thinner pipe .ive got soft soldered yorkshire fittings on my comp between the pump and the tank which gets quite hot and have been on it for over 30 yearsI'm looking to distance my compressor further away from the spray booth and fit an extra drain point, will standard 8mm or15mm domestic copper pipe stand 150psi working pressure?.
Cheers
use 15mm rather than 8mm as u will loose volume using the thinner pipe .ive got soft soldered yorkshire fittings on my comp between the pump and the tank which gets quite hot and have been on it for over 30 years![]()
drawn copper type m int working presure is 776psi @400f thats providing it hasnt been heated and anealed by heating and soldering joints. so compresion fittings would be used at the higher presurehave u ever wached plumbers with a blowtorchI'd be surprised if soldering copper would heat it sufficiently to anneal it. I was of the opinion that copper annealing takes at least 400 deg C to achieve, and more normally at700-800 deg C. Most lead-free solders have melting points in the 220-240 deg C region, so soldering of copper pipe shouldn't result in it reaching the kind of temperature where annealing takes place.
IMHO, of course...
and even more
i neednt say moreQuite, but if you're doing it yourself that shouldn't be a problem, should it? Besides, if you apply too much heat to a solder joint you kill it anyway.have u ever wached plumbers with a blowtorchand even more
i neednt say more
I use a flexible tap fitting from compressor to pipe then the pipe hard into the regulator.
I was initial surprised that the tap fittings form B&Q were rated at a high enough pressure, but they are![]()
Yes, I use a flexible tap hose from the compressor to the solid pipework, seems like a good idea given that the compressor vibrates a fair bit.
