I have a Brooks Compton single phase 3hp motor which has just been returned from the repair shop. This model has a start capacitor and a run capacitor. There was a note with the motor (attached) showing the connections, but I am unsure how to wire this up now.
This is in a Colchester lathe and has four wires from the switch gear, a "run" pair and a pair to set it to forward and reverse. I assume "run" is U1 (Live) and U2 (Neutral) as I had previously used, but where does the switch live and neutral go?
If the switch is to the two terminals marked "SW", that is not how it was wired up previously, but it would make sense.
All help gratefully appreciated, as they are now closed for Easter.
I may well upgrade to a 3 phase motor (as per the OE installation) and an inverter at some point, but I would like to get it running now.
