In the past I’ve used carpet underlay foam. It’s half inch thick, made from chipped foam, so stiff enough to sit on without squishing right down. And it’s cheap, experiments can be done building up in layers.I used to use closed cell EPDM for my Harris, 38mm thick, used to be good for 500 miles in a day. It is all about riding position though.
I was thinking more about the " outer " cover not the foam . Which arrived today and is self adhesive on one side which might be a mixed blessing.Received wisdom tells me you don't need a particularly strong glue for your foam layers. They should be held in place by the vinyl and then you're going to sit on it anyway. A firm strong glue can be counterproductive when layered onto soft foam....
Wiss tinsnips. Good set of secondhand ones. I previously bought some cheap Chinese things and they're so bad I'd be quite happy to send them to you. They are useless though...
<edit> re: glue. If you've ever taken apart an old Japanese seat, the first thing you notice is it's not stuck down to anything. Just a perfectly shaped expanded foam and it simply sits on the bare seat pan.
Where I used to work we used alpha an189 contact adhesive.At home I use contact fix aht100 from as trim which is a bit thin as its sprayable, they do a brushable version though you can't buy it in smaller quantities, not really had a problem with brushing the sprayable one though, worth giving it two coats as it does soak in.Just started lower seat and larger tank for crf230 and will be gluing the cover onto the ally pan can anyone suggest the actual name of a good contact adhesive please. Thanks !
Could anyone suggest a decent pair of tinsnips to purchase as my 50 year old ones have seen better days as have my hands.
Many thanks for your offer of a pair of chineesium snips but as I've already got 3 sets of well worn ones I feel I must decline .
Been using a section of a memory foam wheelchair cushion on the seat of my Beeza for some while now, and it works rather well..Memory foam will simply crush down to nothing. It has no rebound. I have seen people use a thin layer to conform but only when used in conjunction with springy upholstery foam underneath.
Admittedly a hybrid layer that also involves medium density seat foam and sheepskin, but it does work most effectively....
Seems to work pretty well thus far.....Yes it will conform to your body but on a motorcycle, you bounce up and down a lot. By the time you come down, the memory foam will still be compressed, hence the need for springy foam.
Used the stuff on the basis that if anyone needs a comfortable cushion, it's someone in a wheelchair ( speaking from experience ).
It has other layers , as detailed, with the upper layer being sheepskin, wool side down.
Got to be good if they wrap sheep in it.....
My backside, my rules....Yes of course. That is true which Is why I said the same thing above. You can use memory foam alongside regular upholstery foam. Just saying what the drawbacks are and why you can't use memory foam exclusively for motorcycle seats specifically.
Once I have tested the fit for this seat on the bike, I will still need to come up with a fixture front/rear before I get around to sculpting the foam. That's awkward in this case because the owner has done all the fun stuff getting the gross parts of the construction without detailing any issues such as how the tank will be secured, how the seat hump is fitted, where the wiring loom goes, battery etc. etc. So I sort of have to design around these missing essentials and leave some wiggle room for whatever the owner wants to do. Chances are, he'll leave that to me also...
Thanks for all your replies but I'm no nearer to knowing which is the best contact adhesive to use to stick the vinyl COVERING to the underneath of the ALLY seat pan. The foam is self adhesive to the pan on one side only . Any ideas?
I used this stuff, to glue the felt lining in my last hot rod. Also used it to glue rubber to an aluminium radiator. It still sprayed, even after spitting on the shelf for over two years.Thanks for all your replies but I'm no nearer to knowing which is the best contact adhesive to use to stick the vinyl COVERING to the underneath of the ALLY seat pan. The foam is self adhesive to the pan on one side only . Any ideas?
I looks like I'm going to have to draw a picture.Aerosol contact adhesives don't hold to a high temp, personally I would only use them for temp tacking something together.
If its self adhesive surely you don't need a glue.
. Any ideas?
