JOEPRO
- UK
Given that metal expands when red hot and this is why it greatly helps when removing seized fasteners, I have a question.
In a nut scenario it makes sense that if the nut expands then you undo the bolt when the nut is red hot.
What about a case like below where only the bolt head is visible and it goes into a large cast iron exhaust manifold.
In this case would I heat the bolt head red hot with an induction heater then immediately try to undo it? Or allow the bolt to cool for 60 seconds or so then undo? Theory that the hot bolt would expand and crush any rust or thread contamination then when it cools a little it's easier to remove.
