I'll get the size in the morning....
Yes on 6011, straight fillet no whipping or moving at all.6011
Whipped back and forth. Well fused to the rusty base metal, excessive reinforcement for the joint.
Ah AC has given the rippleYes on 6011, straight fillet no whipping or moving at all.
Will get size this afternoon, IIRC 1/4".
Friend gave me a full 50lb box years ago, rarely have a use for them
Here is welder settings:View attachment 492947
This should bring a tear to Donald's eye. An American man using an American machine to manufacture something.
Donald who?This should bring a tear to Donald's eye. An American man using an American machine to manufacture something.
It's a great weld, probably one of the greatest welds in the history of our country.Donald who?
McDonald?
Standard TM-400....they morphed into IIRC TM-500, and then TM-650.@Erie Fred
Bigger picture of Lincoln (USA spec) welder please...?
I interested in these things - I used a "tomb box" one years ago - good thing....
You mean the rounded top 250 amp model with the same crank on front ?
Known as the doghouse.
Driven one many hours.
While I do air arc with it, I'm powerline limited to about 250 amps presently.
Plan to buy some larger wire and pull it thru the underground conduit to the shop...
and then LOOK OUT !
Yup that's the one ^^^ go get it !
90% are A.C. D.C just look at the selector in the upper right, and these will be single phase.
10% or so are only D.C. Reverse and D.C. positive at the switch, and these are 3 phase.
Is this the one you used to drive ?
Lincoln Electric Idealarc 250 Arc Welder | eBay
Lincoln Electric IDEALARC 250 Arc Stick Welder on caster wheels. Welding Leads: 25 foot long welding cables with ground clamp and arc rod holder. Welding Output: 250 Amp. Input Power: 230/460 Volt AC, 60Hz., 1-phase, 66/33amp (Currently setup for 230 volt) (Has 6 foot long power cord with plug).www.ebay.com
Oh god....I don't like those.
This is the model I used - late 80's thing.
Chap on video called it a "tombstone" model.
