Hood
- Carnoustie, Scotland
I am having problems with my EWM Phoenix with an EWM PC2 push pull torch.
Initially I had two problems, one was the arc was sort of bouncing and I found out the pins on the plug had corrosion on the motor power pins, I replaced the pins and it cured that problem.
The second problem is however still there and I am at a loss as to what could be causing it. That problem is I am welding away great then all of a sudden I will get burnback but not like the normal burnback where the wire melts in the contact tip. The wire is actually melting further down in the neck, sometimes it can be close to the end and other times it can be further back in the neck liner. Sometimes it will weld itself inside the brass liner which means it is scrap and it is getting a real PITA as I am going through the brass liners fast.
Anyone have an idea what the problem could be?
Here are some pics of what happens.
