At first thought I would say no, the issue is somewhere else - such as a high resistance, caused by corrosion, in the low-voltage high-current welding output circuit.
When welding, is the power adequate to create a good weld, and roughly which of the power levels, from 1 to 12, does it seem to be fixed at?
As a first step to troubleshoot this fault, could you please measure the DC output voltage, positive on the torch tip and negative on the workpiece clamp? It should vary from about 15v to 38v, in regular increments, as you step up the switch positions. If the front-panel digital voltage display works, does it match the readings on your voltmeter?
